Script Include
sarika ponnagan
In my PDI script Include is not running, while i verified in background script the code is working fine, Created script include and added script include in on change client script, the script include itself not working in my PDI, may i know the reason behind this
@sarika ponnagan Try this
var Ifuserismanager = Class.create();
Ifuserismanager.prototype = Object.extendsObject(AbstractAjaxProcessor, {
    isUserManager: function() {
        gs.log("checking the manager");
        var userId = this.getParameter('sysparm_user_sys_id');
        var grReportee = new GlideRecord('sys_user');
        grReportee.addQuery('manager', userId);
        grReportee.setLimit(1);
        grReportee.query();
        if (grReportee.next()) {
            gs.log("user is manager");
            return true;
        gs.log("user is not a manager");
        return false;
    type: 'Ifuserismanager'
✅ Issue resolved? → Mark as Correct
Found value? → Mark as Helpful
15 REPLIES 15
Hi @sarika ponnagan ,
Have you tried the scripts I have shared?
update the scripts as follows
script include
        gs.info("checking the manager");
        grReportee.addQuery('manager', this.getParameter('sysparm_user_sys_id'));
        grReportee.query();
        return grReportee.hasNext();
client script
    var ga = new GlideAjax('Ifuserismanager');
    ga.addParam('sysparm_name', 'isUserManager');
    ga.addParam('sysparm_user_sys_id', newValue);
    ga.getXMLAnswer(function(answer) {
        alert(answer + ' typeof answer ' + answer);
Chaitanya
@sarika ponnagan Just replied to your previous response with Catalog Client Script.
@sarika ponnagan Can you check this catalog client script:
ga.addParam('sysparm_user_sys_id', g_user.userID);
ga.getXMLAnswer(function(response) {
    console.log("Is user a manager? " + response);
Does the logged-in user have access via ACL? Can you pls check if this Script Include's ACL allows the logged-in user to call it?
Madhav
Viraj Hudlikar
Tera Sage
Hello @sarika ponnagan
Ensure the Script Include is marked as Client Callable.
Use GlideAjax properly in your client script.
Clear browser cache or re-save the script to refresh.
Verify user roles if accessing restricted data.
Try to add some log statements in start of Script Include, so you will get to know if it is getting called or not.
Thanks & Regards
Viraj Hudlikar.
