Set reference field value from flow designer action
ā03-16-2022 05:56 AM
I am having a sample change requests field (list type) in table A. When the record on table A gets closed, I am triggering a change task to create. I need to populate change request (reference field) value with the values from the sample change requests in table A. As its a list type, I need to display any one of the sample change request from the list.
Please find the screenshot below. I am getting the sys id of the change request but its not getting set to the change request field on change task. Kindly suggest any changes
ā11-15-2022 06:03 AM - edited ā11-15-2022 06:14 AM
hi @Mohit Kaushik i have upload a screenshot above . basically i want to get the data(change request number ) from step6 and set it into step7 (field name is change request).
sir change request record generate successfully fine. and also change task is also created when i have apply only parent but when i apply both field change request and parent that time it is not created
ā11-15-2022 06:12 AM
Hi @Aman66,
As i said earlier, scripting is not required. You just have to set the value in change request field as you are setting in parent field. Instead of choosing Trigger-> Requested Item you have to choose value from step 6 -> change request record.
Hope that should help you.
Mohit Kaushik
ServiceNow MVP (2023-2025)
ā11-15-2022 06:23 AM - edited ā11-15-2022 07:24 AM
hi @Mohit Kaushik i am choose like the way change request -> 6 - change request ->number than the flow execution showing complete but did not create the change task
ā11-17-2022 03:02 AM
Hi @Aman66, can you please post the screenshot of your flow and if you see anything in the logs?
Mohit Kaushik
ā03-16-2022 07:27 AM
Yes, for the field the backend name is change_requests.
Trigger record is whenever the record on table A gets closed, then change task gets created.
On the change task the change request backend name is change_request.
With the script ,
