Set reference field value from flow designer action
Renu9
I am having a sample change requests field (list type) in table A. When the record on table A gets closed, I am triggering a change task to create. I need to populate change request (reference field) value with the values from the sample change requests in table A. As its  a list type, I need to display any one of the sample change request from the list.
Please find the screenshot below. I am getting the sys id of the change request but its not getting set to the change request field on change task. Kindly suggest any changes
16 REPLIES 16
Hi Renu,
Please try the below code, this should achieve the requirement.
var chngreq = fd_data.trigger.current.change_requests;
return chngreq;
Mohit Kaushik
Community Rising Star 2022
Mohit Kaushik
ServiceNow MVP (2023-2025)
Seeram
How do I send Configuration Item value in flow designer? Its a reference field and wanted to send to create a incident. Please help out . Thanks
