Set values dynamically to a list collector catalog variable(Groups)
Sarah Bouil
In Catalog form I have a choice field 'Access' with 2 drop down values 'Admin' and 'Non-Admin' and other field is 'Groups'(type is: list collector). If I select 'Admin' as 'Access' then I should see only groups(I mean admin groups) that contains 'admin' role and if I select 'Non-Admin' as 'Access' then I should see only groups(Non admin groups) that does not contains 'admin' role. I tried with below code but it is not working.
Catalog Client Script:
var ga = new GlideAjax('Cat_Var_GetGrps'); //calling script include
if (g_form.getValue('access_user') == 'non_admin') { //access_user- is the drop down variable
ga.addParam('sysparm_name', 'getUserGroups'); //Script include function
ga.addParam('sysparm_name', 'getUserGroupsAdmin'); //Script include function
ga.addParam('sysparm_user', newValue); //On change Value
ga.getXML(Cat_Var_GetGrps);
function Cat_Var_GetGrps(response) {
var filStr = answer;
setMyFilter(answer);
function setMyFilter(filStr) {
eval(groups_dis+'g_filter.reset()'); // groups_dis- is the list collector varaible
eval(groups_dis+'g_filter.setQuery(filStr)');
eval(groups_dis+'acRequest(null)');
Script Include:
var Cat_Var_GetGrps = Class.create();
Cat_Var_GetGrps.prototype = Object.extendsObject(AbstractAjaxProcessor, {
getUserGroupsAdmin: function() {
function groupHasAdminRole(group) {
var hasadmin = false;
var grAdminRole = new GlideRecord('sys_group_has_role');
grAdminRole.addQuery('group.name', group);
grAdminRole.addQuery('role.name', 'CONTAINS', 'admin');
grAdminRole.query();
if (grAdminRole.next()) {
hasadmin = true;
return hasadmin;
var dataArr = [];
var data = {};
var user = this.getParameter('sysparm_user');
var grGroup = new GlideRecord('sys_user_grmember');
grGroup.addQuery('user', this.getParameter('sysparm_user'));
grGroup.addQuery('active', true);
grGroup.query();
while (grGroup.next()) {
var resultAdmin = groupHasAdminRole(grGroup.group.name.getValue());
if (resultAdmin) {
data = {};
data.user = grGroup.getValue('user');
data.group = grGroup.getValue('group');
dataArr.push(data);
return JSON.stringify(dataArr);
getUserGroups: function() {
hasadmin = true;
return hasadmin;
var dataArr = [];
var data = {};
grGroup.query();
if (!resultAdmin) {
data = {};
dataArr.push(data);
type: 'Cat_Var_GetGrps'
Kindly assist me what was wrong with my script?
swathisarang98
Hi @Sarah Bouil,
You can create reference qualifier on Group field and call the script include, in script include check whether the access selected is admin or non admin then based on choice return the value.
Note:the Group field i have used here is of type reference and referencing to sys_user_group.
I have tried in my pdi the below code works please give it a try,
Reference qualifier:
javascript: new  checkRole().getRole(current.variables.access);
Script Include:
var checkRole = Class.create();
checkRole.prototype = {
    initialize: function() {},
getRole: function(choice) {
var groups = [];
if (choice == 'admin') {
              var adminGroup = new GlideRecord('sys_group_has_role');
              adminGroup.addQuery('role','2831a114c611228501d4ea6c309d626d'); // role 'admin' sys_id, checking whether role is admin
               adminGroup.query();
               while (adminGroup.next()) {
               groups.push(adminGroup.group.toString());
               return 'sys_idIN' + groups;
else if (choice == 'non_admin'){
            var nonAdminGroup = new GlideRecord('sys_group_has_role');
            nonAdminGroup.addEncodedQuery('role!=2831a114c611228501d4ea6c309d626d^ORrole=NULL'); //'admin' sys_id, checking whether role is notadmin
            nonAdminGroup.query();
            while (nonAdminGroup.next()) {
                groups.push(nonAdminGroup.group.toString());
    type: 'checkRole'
Please mark this comment as Correct Answer/Helpful if it helped you.
Swathi Sarang
