Sorting reference field lookup
andypollino
Mega Expert
Hi. I have a reference field that refers to a table ('u_infra_cost_of_ram') with two columns that I care about: RAM, an Integer field with internal name of 'u_ram', and Price, a Price field with internal name of 'u_price'. I want users in the Service Catalog to go into the reference lookup and see the RAM values sorted, descending. I tried adding '^ORDERBYu_ram' onto my advanced qualifier (set based on other fields in a Client Script) at the very end, per the suggestion at Sort on a catalog reference field , but that did not work for me. I tried using the advice presented in the thread at How to sort the reference lookup list , but that only sorted the view for me (I want all users to have this view).
I tried changing the RAM field to be a string and then implement the suggestions above, but that did not work either. What can I do to show the user of my service catalog a sorted list?
What information can I provide to help elucidate this question?
Patrick Schult2
Giga Guru
That suggestion where you sorted the reference lookup column - the one that only applied to you - is saved as a User Preference, with your name on it. If you want it to apply to all users, you would locate the User Preference from User Administration > User Preferences, clear the "User" field, and tick the "System" checkbox.
verdakosnett
In attributes for the field: ref_sequence=field_name;
How can we do it in descending order?
