Transform map, skip record rather than ignore
06-15-2020 02:00 AM
06-15-2020 04:18 AM
06-15-2020 04:29 AM
you already have field map then don't use transform script
1) you have choice action as reject so if value not found then it would reject the row
2) did you set the reference value field name as user_name as incoming value is user's user id
set Referenced value field name as user_name
If my answer solved your issue, please mark my answer as ✅ Correct & 👍Helpful based on the Impact.
06-15-2020 05:54 AM
06-15-2020 06:13 AM
Hi bracken91,
Can you please make sure that create new record on emptry colasce field on the transform map is unchecked as shown below
The create new record on emptry colasce field will appear in the transform map level.
Uncheck the create new record on empty colasce fied as shown above.
Please mark helpful and correct.
CB
06-15-2020 06:17 AM
Hi CB,
This is already unchecked
