Using Journal fields and journal input
10-01-2014 02:56 PM
I am using the ServiceNow business edition and trying to create a new application.
Steps done to date:
1, Create a new table by extending the TASK table
2. Personalized the form layout to have different sections that are displayed as tabs
3. In one of the the tabs, I have selected the "Additional Comments" field to be displayed. This field is defined as a "Journal field"
4. When I enter data into the "Additional Fields" column, the data is saved. However I cannot get a Journal listing of the prior "Additional Comments" nor can I see the last entered comment in the journal field.
Is it possible to get the Journal listing on the form?
I will be happy to provide any additional information needed.
Thansk,
Prabakar Narayan
10-01-2014 04:03 PM
I had issues with this too. You should just need a Journal field as specified here in the wiki.
Here's what it looks like on the demo site:
If you right click on the field to show the field details what do you get?
Hope that helps.
- Sherry
10-01-2014 04:21 PM
10-06-2014 12:21 PM
Yes, you want the type to be Journal, not Journal Input. Did that work for you?
- Sherry
10-06-2014 12:38 PM
Thanks Sherry - It sure did work once the field I selected was "Journal" and not "Jounal Input"
