‎09-08-2022 06:18 AM
What is the best way to call system property in a client script (script include) for a catalog item ???
Service Catalog
‎09-08-2022 06:36 AM
you cannot get system property value in client side directly.
you need to use GlideAjax for this and return the property value from the ajax function
Example
Script Include: It should be client callable
var checkRecords = Class.create();
checkRecords.prototype = Object.extendsObject(AbstractAjaxProcessor, {
checkRecordPresent: function(){
return gs.getProperty('property_name'); // name of property here
type: 'checkRecords'
Client Script:
var ga = new GlideAjax('checkRecords');
ga.addParam('sysparm_name', "checkRecordPresent");
ga.getXMLAnswer(function(answer){
if(answer != ''){
alert(answer); // this gives you the property value
‎09-10-2022 05:43 AM
Hope you are doing good.
If my response helped please close the thread by marking appropriate response as correct so that it benefits future readers.
‎09-08-2022 06:37 AM
Hello Rathan,
You can call gs.getProperty("property_name") in script include. But if you are looking to call the System property in Client script then you can use something like below code:
Client Script:
Please user the below code in your Display BR:
g_scratchpad.group = gs.getProperty("user.group.name");
Once you store the property value in scratchpad object you can use it in client script
if (g_scratchpad.group) {
g_form.setValue("group", g_scratchpad.group);
Please mark my respsone as helpful/correct, if it answer your question.
‎09-08-2022 06:42 AM
For Catalog Client script you cannot use the Display BR. You have to use the GlideAjax() to call the script include and then read the property fetched in response:
var CustomerPropertyUtils = Class.create();
CustomerPropertyUtils.prototype = Object.extendsObject(AbstractAjaxProcessor, {
getPropertyValue: function(){
return gs.getProperty('user.group.name'); // Provide your property name here;
type: 'CustomerPropertyUtils'
Client Script:
var ga = new GlideAjax("CustomPropertyUtils");
ga.addParam("sysparm_name", "getPropertyValue");
ga.getXMLAnswer(parseResponseData);
function parseResponseData(answer){
if(answer != ''){
g_form.setValue("group", answer);
‎09-09-2022 06:01 AM
Hello Rathan,
Just wanted to check with you, if the above response answered your question. If yes, then please do close this thread/question by marking the appropriate response as correct.
If you still need any further help or guidance on this then please update those on this question.
