when Incident Priority is changing to 1 - Critical then show a confirm popup message to confirm priority change. "Priority will be changed to P1. Are you sure to proceed with this action?
Arjun Reddy Yer
"when Incident Priority is changing from 3 - Low  or 2 - Medium to 1 - Critical then show a confirm popup message to confirm priority change with OK or Cancel buttons. "Priority will be changed to P1. Are you sure to proceed with this action?"
If user select OK, then only change the priority should change otherwise reset to old value.
If Priority changed to P1 then need to send email to caller.
 @Ankur Bawiskar @Mohith Devatte @Musab Rasheed @Aman Kumar  @Pradeep Sharma
2 ACCEPTED SOLUTIONS
    if(newValue=="1")
var res= confirm('Priority will be changed to P1. Are you sure to proceed with this action?');
  if(res== true){
     return true;
    else{
g_form.setValue('priority',oldValue);
Hello @yerasumalli@gmail ,
You can create a notification for it  on incident table
1)  Create an notification on incident table and check updated check box
2) Give condition as priority changes to 1-critical
3) Go to whom to send tab and select caller as the recipient
and try to change the priority and see if the notification is triggering
Please mark my answer correct if it helps you
12 REPLIES 12
how to Send email to caller when the priority gets changed?
Ankur Bawiskar
@yerasumalli@gmail
Was your question around showing confirm box OR how to send notifications?
The response marked as correct and the question asked is completely different and this might confuse members in future.
Please ensure you mark appropriate response as correct as it would help future members.
