Why my list collector is not in alphabetic order ?
Jean-Michel3
Kilo Explorer
i have make on order guide for choose software.
but the list collector is not in alphabetical order.
the set up is :
Thx for your help.
scott barnard1
Go to that table and look at the list of those records with the filter applied the same as your reference qualifier for the list collector.
Then swap you language and check if the order changes.
We tend to get issues when the french guys create items in french but put the english translation in so the system doesn't have an english translation only a french one that is written in english.
The way to fix it is to go to the record as a user with english language replace the english save the record then swap to french and replace the label and save.
You may not have this it's just something we occasionally have issues with as lots of our devs have languages other than english as their main language
regards
9 REPLIES 9
scott barnard1
Are the records in the list collector translated records?
We sometimes get sort issues if the records were created by a non-english user without an english translation.
How can i see this ?
Hii,
Have you tried by setting No Sort attribute to false.
scott barnard1
regards
Sorry but i dont understand how to fix ...
I tried with english user all is ok.
"The way to fix it is to go to the record as a user with english language replace the english save the record then swap to french and replace the label and save."
