08-18-2022 01:36 AM
Hi community!
I'd like to know if there's a way (or if it is possible) to create a report joining RITM variable sets and Multi-row Variable sets in one report.
Reporting
08-18-2022 01:45 AM
HI Erika,
You can actually report on MRVS by creating a database view, then use that view to report on
- Create a new Database view (System Definition -> Database Views)
- Give it a name like 'u_sc_req_item_multi_var'
- Label like "Multi Row Variable Set"
- Plural like "Multi Row Variable Sets"
- Description like "Joins the sc_req_item to the Multi Row variable set table to be able to report"
- Save
- Under View Tables click "New"
- Table: Requested Item [sc_req_item]
- Variable Prefix: sci
- order: 100
- Where clause: mrqa_parent_id = sci_sys_id
- Click "Submit"
- Table: Multi Row Question Answer [sc_multi_row_question_answer]
- Variable Prefix: mrqa
- order: 100
- Where clause: keep this field blank
- Click "Submit"
You should now have a DBV that looks something like this:
Create a new report
Select Table as source and select your new Database view (Multi Row Variable Set) as the table
You should now be able to create a query and select the catalog item that you want to report on that has the MRVS, as well as adjust your columns to display the Question and Value as well as any other columns you want on your report.
Referred from this thread :https://community.servicenow.com/community?id=community_question&sys_id=252bce56dbd363809a64e15b8a96...
Sandeep
09-02-2026 08:52 AM
I found this thread and had the same issue.
For anyone else coming to this, just add the table you need to the Database View with a Where clause. E.g, I needed to add alm_asset. Then add a Where clause like asset_sys_id = mrqa_value. Then you can pull in the Display value/Name/whatever from that table. Adjust your List Layout as appropriate.
03-04-2024 01:46 PM
Hi all, we also have the requirement to report on RITMs created w/cat items w/MRVSs.
In the screenshot example above, how do you know which set of values were submitted in a single row on the MRVS?
In other words, there is just a random list of Quantity, Description, Model Number, etc... How do you know which ones make up a row on the MRVS ?
04-02-2024 05:52 AM
Did you find a solution for this? I have same requirement
04-02-2024 07:31 AM
We did what Neil P suggested below. Thank you @Neil P.
04-02-2024 07:13 AM
For mine, I group by number, then sort by row index. That groups them sufficiently. An excel output of the table is a little better, sorting wise.
