How to Change System Default for Chart 'Max number of groups'
Mike Turner
Can anyone help identify a method to change the value associated to the 'system default' of the report "Max number of groups parameter"? - this parameter controls how many bars would be shown in a bar report before the 'Other' bar is shown.
The system default seems to be set to a value of 12. We would like to be able to change this system default and all reports rather than going to individual reports and hardcoding a value. This way, our settings are dynamic and uniform .
I have already seen the values stored in sys_choice that associate 'system default' to a choice value of -2 as well as how I would add a new value to the sys_choice table.
Is there a setting that controls what the system default is? - I was hoping to find it as one of the reporting properties but nothing is jumping out at me.
Many thanks
Mike
lakakhan
In order to change the system default for the "Max number of groups" setting in a chart, you will need to access the settings or preferences of the software or program that you are using to create the chart. The steps to do this will vary depending on the specific software or program.
Hifi Forum
Here are some general steps that may be helpful:
  1. Open the software or program that you are using to create the chart.
  2. Locate the settings or preferences menu. This may be found under a "File" or "Edit" menu, or it may have its own icon or button in the toolbar.
  3. Look for an option related to charts, graphs, or data visualization. This may be labeled as "Chart settings," "Graph options," or something similar.
  4. Within the chart settings, look for an option labeled "Max number of groups" or something similar.
  5. Change the value to your desired setting.
  6. Save the changes and close the settings or preferences menu.
Please note that this is a general instruction, it may differ from the software you are using.
Can you please let me know how to achieve this in Platform Analytics when we do group by? I need 1 in Max number of groups which is currently not there.
Harsha
Did you find the solution to do in Platform analytics?
