I need a scripted breakdown that will dot-walk from metric_instance to the ID field to fields that are on that document ID
George P
I am attempting to create a breakdown that looks at certain records on the metric_instance table and breaks down on the ID.User field.  Can someone provide some guidance on how I would make a script dot-walk through a document ID field?
Adam Stout
Don't use a script for this.  You'll get much better performance if you create a view to the table you are looking for (e.g., incident, case, etc.) and then build your indicator on that.  There was a lab on this at K19 which walks you though using Performance Analytics on metrics. (I believe it is this one: https://community.servicenow.com/community?id=community_article&sys_id=686623dcdb9d3b0422e0fb2439961...)
Adam Stout
Analytics is a team sport.  To get the Performance Analytics to do what you need it to, there will be use cases when changes to the application (like a database view) are required.
