Software Asset Management Process Guide
Yvonne12
Hi
Is there a current version for this document-see attached?
(Software Asset Management Process Guide_Paris Process Guide 2020)
If so, please send me the document or link.
Yvonne12
Are you looking for this?
Software Asset Management (SAM) Process Guide
Rome
see attached
Yes, thank you.
Glen Moore
Giga Contributor
It's quite a complicated process. Today, it has become insufficient to conduct a SAM project and consider that the issue has been closed for a long time. The situation with software assets in a company changes quite dynamically. Most importantly, business tasks and the ways to solve them are also very fluid and often tightly linked to the software.
Inespolo
Yes, I have had similar errors. Usually, they occur because you have a malfunction in the software. It can also be due to errors in the service center of the application you want to use.
Inespolo
Yes, I have had similar errors. Usually, they occur because you have a malfunction in the software. It can also be due to errors in the service center of the application you want to use. Try to check if the proxy servers are loading properly - that could also be why. If everything is working properly, then it's really about the software. I not only had this problem when I was using the internet but also when I created my own application. I needed the help of https://www.exposit.com/solutions/ to fix it. Perhaps it can be useful for website or app developers as well.
