Advanced reference qualifier help
Hello, I'm trying to set up a filter on a dictionary override, however I cant seem to get the script include to work. Any ideas where its falling over?
Its on the assigned to field and it should only show people in groups where the assignment type is **sys_id** below.
Thanks in advance!
var PCRFilter = Class.create();
PCRFilter.prototype = Object.extendsObject(AbstractAjaxProcessor, {
    filter: function() {
        var groupids = [];
        var groupgr = new GlideRecord('sys_user_group');
        groupgr.addEncodedQuery("group.u_assignment_type_sLIKE3077280b1b67921074ba9604b24bcb80");
        groupgr.query();
        while (groupgr.next()) {
            groupids.push(groupgr.getValue("sys_id"));
        if (groupids.length == 0) {
            return "";
        var userids = [];
        var grmember = new GlideRecord("sys_user_grmember");
        grmember.addQuery("group", "IN", groupids);
        grmember.query();
        while (grmember.next()) {
            userids.push(grmember.getValue("user"));
        return userids;
    type: 'PCRFilter'
javascript: new PCRFilter().filter();
This was helpful however I think I went over the top with the referencing.
In the end I got this to work.
        var userids = [];
        var milestone = current.getValue("u_milestone_record"); //Check if Milestone Record is empty
        if (!milestone) {
            return "";
        var grmember = new GlideRecord("sys_user_grmember"); //check the user membership table
        grmember.addQuery('group.u_assignment_type_s', '=', '7cf4ac0c1b735a10408c4156b04bcb79');
        grmember.query();
        if (userids.length == 0) {
            return "";
        return "sys_idIN" + userids.join(',');//Return the sys_id of the user against the group
    type: 'PCRFilter'
Anurag Tripathi
Giga Patron
Try to return encoded query instead of sys_ids.
EG
return "sys_idIN"+userids.toString();
-Anurag
        var userids = [];
        if (!milestone) {
            return "";
        grmember.query();
            return "";
    type: 'PCRFilter'
Zuhaib
This video shows how to use an advanced reference qualfier on a list collector type variable on a catalog item in ServiceNow.
