Auto update field values
devservicenow k
My requirement is to Auto update field values after 5 days of creation.
Record is created--> after 5 days --> short_description (" alert 5 days) field should be auto updated.
how to do this in Schdeuled job?
suvro
Create a workflow on that table and it should run on insert
In the worklow use a timer activity to wait for 5 days
then use set value activity to set the necessary field with desired value.
yeah i have made , but i need to do in schdeuled job.
Use this
   var actualDateTime = new GlideDateTime();
   var gr = new GlideRecord('table_name');
   gr.addActiveQuery();
   while(gr.next()){
      var dur = new GlideDuration();
      var updatedOn = new GlideDateTime(gr.sys_updated_on);
 dur = GlideDateTime.subtract(updatedOn , actualDateTime );
     dur = dur.getDaysPart();
      if(dur >= 5){
         gr.short_description = "YOur short description";
         gr.update();
eagle18
Hi @devservicenow k
You can do this in flow designer with no need to write any scripts. Better approach than using workflow
Flow Designer Wait Condition
