03-10-2021 05:40 AM
Hi all,
I am using a reference field as below in my catalog item. On the portal I am able to see this variable in the catalog item and the options / drop downs but users see empty. Why would this be? This is also happening to another variable for Cost Codes. Again I can see the options to the drop downs (all the list of cost codes) as admin but users can not.
Service Catalog
03-20-2021 11:07 AM
The read ACL on this particular table might have some roles required(like contract manager, model manager). Since you said users accessing this field doesn't have any roles, you might wanna create a new read ACL with No roles required.
Please be aware that you must consider the security issues that might come up when you give the read access for this variable to the users.
Pratyusha
03-10-2021 06:31 AM
What if I create a new READ ACL with no roles, will this work?
03-10-2021 06:48 AM
yes it would work
Just to check -> if you create read ACL with no roles and system adds snc_internal role to it then you will have to give those users that snc_internal role
03-18-2021 03:29 AM
Hope you are doing good.
Would you mind marking the best matching answer as correct and helpful, to close this thread?
03-10-2021 05:47 AM
Do the users have read access to that table?
03-10-2021 06:05 AM
This now I realise, the read access is set to specific roles. If I removed the roles, will this then be able to all? As users dont have any roles.
