choice field value not showing in flow designer.
Nasreenfathima
Giga Expert
I have a catalog item in that i have a multiple choice variable , i need to get the value from this variable and need to show this in cmdb resource group table in environment choice field.
How can i achieve this? Thanks in advance.
then use inline script and use if else
get the catalog variable value and compare it and return the correct choice value for that field
15 REPLIES 15
In get catalog variables i have selected this sh_srvc_tier , but still , its showing this.
Please share complete screenshots.
you can use the data pills and set the value directly without using any script
I have tried to use the data pill, but , in that i am getting the backend value like Instead of "production" , i am getting "sh_production". In Cmdb resource group table in environment field one new chioce "sh_production" added .
that is what I mentioned; choice values should be same in both
Then using data pill it would work directly and no script is required
one new choice is created as sh_production and that value dispalyed. I want only Production as it already there.
Choice values are different and choice name only same
