choice field value not showing in flow designer.
Nasreenfathima
Giga Expert
I have a catalog item in that i have a multiple choice variable , i need to get the value from this variable and need to show this in cmdb resource group table in environment choice field.
How can i achieve this? Thanks in advance.
then use inline script and use if else
get the catalog variable value and compare it and return the correct choice value for that field
15 REPLIES 15
please ensure choice values are same in both variable and field
Choice values are different for both. catalog variable and cmdb resource group table.
var env  = fd_data.subflow_inputs.requested_item.variables.sh_op_env_bc;
if(env == 'sh_Production'){
return 'Production';
else if(env == 'sh_Acceptance'){
return'Acceptance';
else if(env == 'sh_Development'){
return'Development';
else if(env == 'sh_Test'){
return'Test';
It worked
