Create multiple records through Flow Designer from Record Producer
mballinger
Mega Guru
I have a record producer with multiple Multi Row Variable Sets. I need to create a flow, when a record is created from the Flow, it needs to grab all the line items from each MRVS and create a new record.
How can I do this?
Thanks!
@mballinger
You can also use after insert BR on your record producer target table
Sample Script below
I assume your MRVS has name and email variable
	var value = current.variables.variableName;
	if(value){
		var parser = JSON.parse(value);
		for(var i=0;i<parser.length;i++){
			var gr = new GlideRecord("tablename");
			gr.initialize();
			gr.u_name = parser[i].name;
			gr.u_email = parser[i].email;
			gr.insert();
})(current, previous);
✨ Certified Technical Architect  ||  ✨ 9x ServiceNow MVP  ||  ✨ ServiceNow Community Leader
We want to do it from Flow Designer because there are other actions that will need to be performed, but in the flow designer the only option it gives for a selection is Service Catalog
@Ankur Bawiskar - No name and email does not exist. I am trying to avoid creating a workflow through workflow editor. It has been recommended to use Flow Designer.
@mballinger
That was my 1st question and I informed about that.
Flow designer doesn't work on record producer.
So if you cannot do that using flow then use after insert and the logic I shared.
Just use correct field names from custom table and correct mrvs variable set name and the variables within MRVS
I have created a flag on my RP and our custom app. The flag is called "Created from RP". When the RP is submitted, I map the fields to the record. I now have a way of triggering a Flow.
Now, from the flow designer, how can I create new records from MRVS?
Thanks!
@mballinger
If you are unable to get the MRVS variable value in your flow using the Get Catalog Variables you cannot proceed with the Flow approach.
So the final method would be to use after insert BR and the sample script I shared.
