06-03-2021 07:33 AM
I have a record producer with multiple Multi Row Variable Sets. I need to create a flow, when a record is created from the Flow, it needs to grab all the line items from each MRVS and create a new record.
How can I do this?
Thanks!
06-03-2021 08:02 AM
You can also use after insert BR on your record producer target table
Sample Script below
I assume your MRVS has name and email variable
var value = current.variables.variableName;
if(value){
var parser = JSON.parse(value);
for(var i=0;i<parser.length;i++){
var gr = new GlideRecord("tablename");
gr.initialize();
gr.u_name = parser[i].name;
gr.u_email = parser[i].email;
gr.insert();
})(current, previous);
✨ Certified Technical Architect || ✨ 9x ServiceNow MVP || ✨ ServiceNow Community Leader
06-16-2021 08:27 AM
I used the code you provided and passed it through the RP vs the BR or a flow. Thanks again for your help!
