Dictionary info is not showing up when I right click on a field in a form and click on show field.
02-12-2025 05:21 AM
Hello All,
Dictionary info is not showing up when I right click on a field in a form and click on show field name
02-12-2025 10:23 AM
06-09-2025 12:01 AM
Hi @Dr Atul - LNG|
I guess i too experience the same issue here and attaching the screenshot.
any inputs here?
06-09-2025 03:49 AM
06-09-2025 12:17 AM
I’ve faced this issue before. If the Dictionary entry option is not visible when you right-click on the field name, it might be due to performance issues on the form.
Please double-check if you have any Client Scripts or UI Policies applied to the form. Sometimes, a large number of scripts or heavy logic can impact performance, which may prevent certain right-click options (like "Show Dictionary") from loading properly.
I suggest disabling them temporarily and trying again to see if the dictionary option becomes visible.
