Display custom dialog box
NehaReddyH
I have a dropdown field "status" on my form and im looking for a way to create a dialog box with three options "cancel", "cancel but dont send" , "send". When a user changes a status to cancel, this dialog box should appear with these three options and when user clicks on send, a notification should be sent. When 'cancel but dont send' is selected then status will be updated. I dont have much knowledge on UI page scripting. Can anyone help me to achieve this functionality?
Thanks in advance!
Hi Neha,
I don't think directly you can use "cancel_project_button" in processing script
only html hidden element id's can be access directly in processing script
please update code as below
HTML:
After line 4 add this line
<input type="hidden" id="hiddenElement" name="hiddenElement"/>
in client script make this change for both the functions
Client Script:
after line 6 add this
gel("hiddenElement").value = 'cancel clicked';
after line 11 add this
gel("hiddenElement").value = 'send clicked';
now in processing script check this
Processing script:
if(hiddenElement == 'cancel clicked'){
gs.info("cancel project called");
//send notification
else{
gs.info('send button clicked');
13 REPLIES 13
Hi Neha,
HTML:
Client Script:
Processing script:
//send notification
else{
Hi Neha,
Hope you are doing good.
Let me know if I have answered your question.
If so, please mark appropriate response as correct & helpful so that this thread can be closed and others can be benefited by this.
If not, please let us know if you need some more assistance.
AbhishekGardade
Tera Sage
Hello Neha,
Have a look on below blog:
Custom Glide Modal Dialog Boxes
SweetAlert
Please mark as Correct Answer and Helpful, if applicable.
Thank You!
Abhishek Gardade
Thank you,
Abhishek Gardade
I have created a UI page with name 'cancel_action' and im calling it from client script but the UI page is not rendering. can you suggest what the issue could be?
script:
var dialog = new GlideDialogWindow("cancel_action");
dialog.setTitle("Send Notification");
dialog.setSize(550, 500);
dialog.render();
