Displaying Yes/No values on a True/False field
Micaela Alberti
Hi!
I created a "True/False" field and displayed it with a drop-down list with none, since the field will be a mandatory one.
I created related choices to the field in order to display:
No -> for "false" value
Yes -> for "true" value.
The system is skipping it even though I put 0 and 1 as values and it is always displaying "true" and "false" as choices. Do you have any suggestions on how to do this without changing the type of the field?
Thank you
Micaela
Sandeep Kumar6
Giga Guru
Hi Micaela,
I understood your requirement.
What you can do is take one choice field and configure two choices in that like "True" --> Yes  and "False"--> No or vice versa
See the below diagram to do this.
In this case whenever you want to access the value of this choice field it will give you Yes or No. or configure vice versa you will get True or False.
 I wrote a on change client script to populate value and below is how I get answer exactly you needed.
Please mark correct if this gave you correct answer.
Sandeep
Thank you Sandeep.
I am just trying to have a drop down list with "yes" and "no" values, using a field type "true/false"
Micaela
Hey Micaela,
I have checked regarding this but this is not what ServiceNow provides.
There are different field types for respective purpose.
Sandeep
The best approach would hide the "True/False" field and create dropdown having None, True, False. Write a BR/Client Script on insert/submit set the field value using the script. So that if there are any existing scripts depending on the field and filters will not get affected.
