Does Knowledge articles and knowledge categories capture in update set
Ansuha Chipuri
Does Knowledge articles and knowledge categories capture in update set.
if no, how can we move articles and categories added in dev to test
Ankur Bawiskar
@Ansuha Chipuri
Nope both are not captured
1) export import category via xml
2) then export import the articles via xml
Hi Ankur,
Will this export/import copy over all metadata and versioning?
Thanks-Kevin
Definitely not versions, not sure about metadata
Anurag Tripathi
Giga Patron
Check this blog, it answers all your questions#
What Gets Captured In Update Sets
Mark helpful if you like it.
-Anurag
