Flow designer : Flow is not triggering
davjohn
Kilo Expert
Hello Team,
I'm trying to trigger a flow for the sys_history_line table but for some reason the flow is not getting triggered.
I tested the flow using a sample test from the designer itself and I'm able to achieve the required output but the flow is not getting triggered after activation.
Please help !!
Mario Quinones1
Mega Guru
Have you checked who is running the flow under "Properties"?, if it is not "System user", try with that one.
Also check the "Today's executions" to see if here is an error happening.
Ankur Bawiskar
@davjohn
I would recommend to avoid Flow on that table as it is very huge table and is system OOB table.
Now to your point please check what Mario has mentioned who is the Run as user
Yes i'm building it for a POC and I wanted to trigger this flow only for a particular table.
I will re-consider the requirement and try to trigger the flow from the cutom table only.
Mean time I tried running it as system user still I don't see any triggered execution.
@davjohn
Sure.
I believe you should be raising HI ticket with ServiceNow for the issue.
