Flow designer - list collector - how to display multiple values
Kifrez
Hi all,
Could someone please help me with list collector variable and flow designer?
I have a catalog item with list collector variable. I am trying to use flow designer to display the values.
Flow designer will list if there is only one value . however, if more than one, it comes up as blank.
How do I incorporate the script in below link so I can display the value in description?
I think it's a bug from the system.
Flow Designer: how can you retrieve values in an action of a glide_list object? - Support and Troubl...
Thanks in advanced for your assistance.
I mean here's my test flow:
If the network drives List Collector points to a table, you should be able to do the same just by plugging in your variable into step 2.
Could you post a screen shot of the definition of the list collector?
22 REPLIES 22
I mean what items are there if you expand shared_mailbox?
All the columns in the mailbox table. It’s so bizarre
Well, a mystery to me. 🙂
Seems to be a bug, only SN could say.
