glide record for loop help
Gary22
hi All ,
i have a list of incidents stored in a variable ( separator is comma )
var1 = 'inc1 , inc2 , inc3'
In my server side script i need to do a glide on the incident table and query for each incident number , one by one ( first query for inc1 , then query for inc 2 in a loop ).This is a basic scripting question i know but need some hint on how to fetch the comma separated values into the for loop one by one , , so that i can then do a glide query .
thanks a lot in advance
Harish Bainsla
hi check below code
var var1 = 'inc1, inc2, inc3';
var incidentNumbers = var1.split(', ');
for (var i = 0; i < incidentNumbers.length; i++) {
    var incidentNumber = incidentNumbers[i].trim();
    gr.addQuery('number', incidentNumber);
    if (gr.next()) {
        gs.print('Incident ' + incidentNumber + ' found. Do something with it.');
        gs.print('Incident ' + incidentNumber + ' not found.');
Vallabh Baradk2
Giga Guru
Hello @Gary22 ,
You can try below code:
var a='INC6488096,INC6481267,INC6481266';
var gr1=new GlideRecord('incident');
gr1.addEncodedQuery('numberIN'+a);
gr1.query();
while(gr1.next()){
gs.print(gr1.getValue('number'));
Output:-
Please mark correct or helpful if it really works for you.
Vallabh
