08-20-2015 12:39 PM
I know that there are several discussion and guides on the subject, but after several tries (and cries) I am simply not able to have any videos displayed in my knowledge articles.
I have tried uploading a video to the library, embeddign the video (youtube), linking to the video (youtube), and nothing works.
Once I hit SAVE, the video disappears from the KB article and from the source-code of the article.
Am I missing something???
Please help me, I am loosing my f***** mind here!
Knowledge Management
08-21-2015 02:47 AM
Solution from HI.
Solution Proposed:
I found that when you save a kb_knowledge record with an embedded video in the HTML field, the security layer strips out the object tags from the html field. As a workaround, we configured the dictionary entry of the Text field and added a dictionary attribute called html_sanitize=false. This allowed the video to be embedded properly. The documentation for this is located here:
https://hi.service-now.com/kb_view.do?sysparm_article=KB0547641
Workaround:
The workaround was applied to the field text from KB form > attributes tab
08-20-2015 01:08 PM
Ugh... man it sounds *exactly* like what I was dealing with. The HTML editor interprets the embed code as garbage and just throws it away.
You opened a /hi ticket yet?
08-20-2015 01:42 PM
Experiencing the same thing in my instance. I'll try to look into this a bit tonight and get back to you. If you have a /hi ticket and they get back to you before I update hte thread, please let me knows
08-21-2015 01:58 AM
I have raised a HI ticket and will update this thread once I get an answer..
08-21-2015 02:47 AM
Solution from HI.
Solution Proposed:
Workaround:
08-21-2015 05:54 AM
That's two versions now that have been plagued by that issue.
