How to enable 'Add to cart' functionality on CSP portal for order management?
12-02-2025 11:12 PM
I want to add 'Add to cart' functionality on the 'CSP' portal for the order management just similar like catalog items on the service portal. Currently i am not able to find any option or field to enable add to cart for the csp portal.
I have also check in csp portal and its header menu widget but not found any thing.
Do I need to manually configure it or is their any way to add it on the csp portal for order management.
12-03-2025 09:34 PM
Seems you missed my earlier response
if your catalog item is record producer then Add to Cart is not available for it
12-03-2025 01:49 AM
Would you mind closing your earlier questions by marking appropriate response as correct?
Members have invested their time and efforts in helping you.
