How to insert line break in Flow variable in Flow designer?
Sunil Kumar_ P
I have created a flow variable and I would need to insert the line breaks in that. The format should like the below.
Ex:
Device -  Abc
Serial Number - Xyz
Can any help suggest how this can be done please?
Patryk Misiasze
Try using <br/> where you need a new line.
In your case it would be something like this:
Device -  (pill containing Abc) <br/>Serial Number - (pill containing Xyz)
Sunil Kumar_ P
Hi Patryk,
I have tried it but no luck. However, I am able to use the replace string transform function with <br /> in it and it worked.
Are you using it in Flow Logic 'Set Flow Variables'? It worked well for me.
Anyway, I'm glad you were able to solve your problem.
