How to return a value from a script step in flow designer.
Sonu Singh
Mega Expert
I need to fetch a value from the response body which i have received it from the SOAP step:
Fig:
Can some help me how do i fetch any value from the xml response which i am getting in the responsebody input variable?
Ak
So the problem is the body which is returned from integration.
See formatted XML
Below works but it's not good for long time solution.
var response = inputs.response_body.toString();
var xmldoc = new XMLDocument(response);
if(xmldoc.toString().indexOf('name=') > -1){
	var nm1 = (xmldoc.toString().split('name="')[1]);
	var nm2 = (nm1.toString().split('"')[0]);
	outputs.groupname = nm2;
41 REPLIES 41
So you are getting xml as response; you can directly parse it and set the value
Is it not setting the outputs variable using this
var response = inputs.response_body;
var name = xmldoc.getNodeText("//row/@name");
outputs.groupname = name;
@Ankur Bawiskar ,
I tried this but i am not getting anything for outputs.groupname=name;
Mike Patel
Tera Sage
Lets add logging so we know what we are getting
try below
gs.log("response: " + response, "Soap");
gs.log("xmldoc: " +xmldoc, "Soap");
gs.log("name: "+name, "Soap");
@Mike Patel ,
For this i am getting soap xml response.
No response
since no response for the above step:
Can you share what you got for response in logs ?
