How to return a value from a script step in flow designer.
Sonu Singh
Mega Expert
I need to fetch a value from the response body which i have received it from the SOAP step:
Fig:
Can some help me how do i fetch any value from the xml response which i am getting in the responsebody input variable?
Ak
So the problem is the body which is returned from integration.
See formatted XML
Below works but it's not good for long time solution.
var response = inputs.response_body.toString();
var xmldoc = new XMLDocument(response);
if(xmldoc.toString().indexOf('name=') > -1){
	var nm1 = (xmldoc.toString().split('name="')[1]);
	var nm2 = (nm1.toString().split('"')[0]);
	outputs.groupname = nm2;
41 REPLIES 41
@Mike Patel
gs.log i didn't logged anything in syslog_list so. i passed those value to output.
try
var response = inputs.response_body.getDisplayValue();
gs.log("response: " + response, "Soap");
gs.log("xmldoc: " +xmldoc, "Soap");
var name = xmldoc.getNodeText("//row/@name")
gs.log("name: "+name, "Soap");
I could see null in the name variable?
Did you not get the proper xml response?
@Mike Patel  & @Ankur Bawiskar
No image
