05-07-2020 03:28 AM
I need to fetch a value from the response body which i have received it from the SOAP step:
Fig:
Can some help me how do i fetch any value from the xml response which i am getting in the responsebody input variable?
Ak
Flow Designer
05-08-2020 11:34 AM
So the problem is the body which is returned from integration.
See formatted XML
Below works but it's not good for long time solution.
var response = inputs.response_body.toString();
var xmldoc = new XMLDocument(response);
if(xmldoc.toString().indexOf('name=') > -1){
var nm1 = (xmldoc.toString().split('name="')[1]);
var nm2 = (nm1.toString().split('"')[0]);
outputs.groupname = nm2;
05-08-2020 08:14 AM
image is missing?
05-08-2020 08:21 AM
05-08-2020 08:24 AM
Looks like it’s not gettin whole XML response instead getting only first line.
05-08-2020 08:26 AM
it's just the first line
only this is getting logged <?xml version="1.0" encoding="utf-8"?>
05-08-2020 08:29 AM
since the response is null; you are unable to parse it
When the response is valid is it fetching the name correctly?
