How to run a script within ATF.
VIKAS MISHRA
Manually i can use the background script to run the below mentioned script and update a particular field value, However now wants to know how can i run below mentioned script to update a field value within ATF.
Script:
var gr = new GlideRecord('x_amex_sourcing_request_request');
gr.addQuery('number', SRCENG0036058);
if(gr.next()){
gr.x_amex_sr_si_service_description = 'Testing by vikas';
gr.update();
14 REPLIES 14
Here you can see the step no. 34 which i have created for  the script that i am writting to update the field value.
so which record you are inserting?
which step is that?
It is step no. 34 "run server script" that i am using to update one of the field's value.
Below i have attached the screenshot of that step and the script that i am using there.
line 81,82, 86 not required
also give the step sysId which has that record
Hi Ankur,
This still not working we have tried below mentioned code there but its doing nothing.
Could you please confirm if this is actually possible or not i mean to update the field value as we can do through background script.
(function(outputs, steps, stepResult, assertEqual) {
//gr.addQuery('sys_id','de8cace91beb8d106f82ca6b234bcb9d');
//gr.get(steps('sys_id').first_record);
gr.get(steps('39f955d31b0f81906f82ca6b234bcb48').record_id);
//gr.addQuery('sys_id','39f955d31b0f81906f82ca6b234bcb48');
if(gr.next()){
gr.x_amex_sr_si_service_description = 'Testing by vikas000';
gr.update();
