09-15-2020 10:29 PM
I am using Cart api to set Requested_for field for different users,but still the requested for is showing my name only
is there any way to set the requested_for by using Cart API
Service Catalog
09-15-2020 10:50 PM
Unfortunately you cannot set any fields of REQ or RITM using Cart API
the only way is to get the REQ sys_id and then set the value
sample script below
var cartId = GlideGuid.generate(null);
var cart = new Cart(cartId);
//add your requested item to the cart by sys_id of the catalog item
var item = cart.addItem('4054428fdb151f0097679ec6db9619c0', 1);
//fill in the variables on the request item form
cart.setVariable(item,"u_requested_for", "e80edd6edbec6bc097275e25ca9619a4");
cart.setVariable(item,"contact_number", "0");
cart.setVariable(item,"assignment_group", "87ec1c342b2e71406c487fb5a8da1524");
cart.setVariable(item,"application_service", "cdedfbcedb0f9744c291c170ba9619a7");
var rc = cart.placeOrder();
var reqRecord = new GlideRecord('sc_request');
reqRecord.get(rc.sys_id);
reqRecord.requested_for = 'user sys_id you want here';
reqRecord.update();
04-14-2021 01:10 PM
I have this working. When you create the a cart object by calling the Cart API, the user sys_id you pass in becomes the request's "Opened by" user.
When the cart object is instantiated, it creates cart property, which is a GlideRecord. You can change the properties of this cart GlideRecord, but it doesn't have an impact when the request is created.
Instead, you need to recreate the cart property, and set the requested_for user using the setRequestedFor() command.
var requestedForUser = "user sys_id";
var openedByUser = "user sys_id";
var cart = new Cart(cartId, openedByUser); //
// In the cart object there is a cart property
// We need to recreate this cart property to set the
// Requested for user
var tempCart = GlideappCart.getCartForRhino(cart.cartName, cart.userID);
//Now we can set the requested_for user on the temp cart
tempCart.setRequestedFor(requestUser);
// Make the tempcart the cart's cart
cart.cart = tempCart.getGlideRecord();
Hope this helps someone.
Cody
07-05-2021 05:48 AM
Take a look at the script includes SPCart. I mentioned it's use in this post years ago, but I discovered a better way to set the opened_by and requested_for fields independently, after revisiting a requirement in our instance.
var cat_item = ""; //Sys ID of the catalogue item you're adding
var opened_by = ""; //Sys ID of your opened by user
var requested_for = ""; //Sys ID of the requested for user
var cartId = GlideGuid.generate(null); //Generate the sys ID for the cart
var cart = new SPCart(cartId, opened_by); //Create the cart with the opened_by user
var item = cart.addItem(cat_item); //Add the item to the cart
//Define your variables
//cart.setVariable(item, <variable name>, <variable value>);
cart.setRequestedFor(requested_for);
var SCrequest = cart.placeOrder();
