How to sort advanced reference qualifier for a reference field?
Bharati Paidiap
I am using a script include for reference qualifier, but now the list should be sorted . Is there any way this can be achieved?
19 REPLIES 19
chetan1742
Can you provide your script include code?
Voona Rohila
Hi
You can use orderByDesc/orderBy to sort the
gr.orderByDesc('field_name'); //descending order
gr.orderBy('field_name'); //ascending order
Example:
gr.orderBy('number');
gr.orderBy('sys_created_on');//ascending order by created date.
Bharati Paidiap
Am not really glide recording anything rather just returning an encoded query.
return 'u_category=' + current.u_case_number.u_dispatch.u_category + '^u_field_name=u_billableratecardcategory' + '^u_mapping_type=Value' + '^u_active=true'+'^ORDERBYu_label';
Looks like orderby is already added, Is it not working?
return 'u_category=' + current.u_case_number.u_dispatch.u_category + '^u_field_name=u_billableratecardcategory' + '^u_mapping_type=Value' + '^u_active=true^ORDERBYu_label';
