ā06-16-2020 11:25 PM
Hi all,
I am working on creating Flow Designer for Inbound Email and the target table is the custom table "Alert Record" which is in custom application scope. But I am getting error while creating a record in the table, but not able to get what's the error.
I am getting error in the Create Record part. It's working fine when I use the test option in flow designer, but when I send the email it's showing error in the execution details. Could anyone suggest how to debug the flow or fix the error.
Mithun
Flow Designer
Notifications
ā06-17-2020 05:44 AM
Hi all,
I was trying to Run As - User who initiates Session, and the user didn't have the access/role to create the record. Once the user was given the role it's working as expected.
Note:
When a flow runs as a user, the user needs permissions to run the actions executed by the flow. For example, if a user initiates a flow that creates a record, but the user does not have permissions to create the record, the flow stops execution with an error.
Flows that run as the user who initiates the session are safer because they do not execute with the elevated privileges of the System User.
If a flow needs to run with elevated privileges, a developer can set the Run As flow property to System User.
Thank you for all your responses.
Mithun K R
ā06-17-2020 01:01 AM
This is a pure cross scope issue: You have to create entries in cross scope application module and then also enable can create. If not then you cant create it from other scopes.
From global yes but not from other scoped apps.
One more thing:
Use which you are using has access to the create records in this scope.?
Ashutosh
ā06-17-2020 01:28 AM
Hi Ashutosh,
I have changed the application scope accessible from all. Do I still have to create record in cross scope privilege?
Mithun
ā06-17-2020 01:47 AM
I think so. You can try that. What i know is we have to create a entry cross scope application even if the table access is marked as all scope and can create.
If you have run time access then in caller access it will create entry automatically and then you have to allow it there.
Ashutosh
ā06-17-2020 01:48 AM
ā06-17-2020 01:08 AM
Hi Mit,
can you share the error screenshot what it tells
