I am not able to figure out the error in flow designer
mit2324
Kilo Expert
Hi all,
I am working on creating Flow Designer for Inbound Email and the target table is the custom table "Alert Record" which is in custom application scope. But I am getting error while creating a record in the table, but not able to get what's the error.
I am getting error in the Create Record part. It's working fine when I use the test option in flow designer, but when I send the email it's showing error in the execution details. Could anyone suggest how to debug the flow or fix the error.
Mithun
mit2324
Kilo Expert
Hi all,
I was trying to Run As - User who initiates Session, and the user didn't have the access/role to create the record. Once the user was given the role it's working as expected.
Note:
When a flow runs as a user, the user needs permissions to run the actions executed by the flow. For example, if a user initiates a flow that creates a record, but the user does not have permissions to create the record, the flow stops execution with an error.
Flows that run as the user who initiates the session are safer because they do not execute with the elevated privileges of the System User.
If a flow needs to run with elevated privileges, a developer can set the Run As flow property to System User.
Thank you for all your responses.
Mithun K R
15 REPLIES 15
Hi Ankur,
Now I have changed the application scope to all. And the error screenshot I have already added at the beginning of the post.
Mithun
Hi Mithun,
it just says error but not the error message
Ideally both table and flow are in same scope then it should not cause an issue
Did you check by having simple flow of just creating a record as single step?
Muralidharan BS
HI,
Its worth trying to change the flow,
to
/Murali
mit2324
Kilo Expert
Hi all,
Note:
Mithun K R
Hi Mithun,
Kindly mark my response correct if my suggestion helped you,
Murali
