Is it possible to have a task for knowledge article?
My requirement is to have an Assignment Group field on Knowledge Articles and assign a task to that group a month to valid date.
I started with the workflow on Kb_knowledge and I don't see and Task activity. Is it possible to have a task for knowledge articles or, would you suggest some other way to do this?
I created a Knowledge Task table extending Task table and creating tasks from a workflow.
I would just use the task table and create a TASK record instead of extending the task table. It can also be taken care as a Service Request.
If you can create a Service Reques, RITM and a task under it, that should work as well for them.
thomashansson
In Paris there are some enhancements. Have you looked at:
Email notifications for expiring articles
Review knowledge articles that are about to expire using email notifications.
Ownership groups
An article is scheduled to expire in the next month with the ownership group feature enabled.
  • Author
  • Knowledge base owner and managers
  • Reviser for the updated and checked-out versions
  • Ownership group manager and members
@rajinis  did you edit the OOB workflow and added the task activity?
Could you please share what else had to be updated?
