issue while using glide_list attribute for list collector in record producer
kalp
i have created a field with type list collector,
even after using glide_list attribute, its still showing the same  in record producer form, can someone help on this.
And also my requirement is search by user id, name should populate,how to achieve this.
regards,
Kalyani
-O-
The complete attribute specification:
ref_ac_columns=user_name;employee_number,ref_auto_completer=AJAXTableCompleter
-O-
Dis you also define attribute ref_auto_completer?
E.g:
The latter enables showing the additional field mentioned in attribute ref_ac_columns.
See details in Service catalog variable attributes.
-O-
kalp
Thanks, it showing name along with id , when i search by name, this will be helpful ithink.
But if i search by id, its not showing any matches, will searching by id work, instead of name
-O-
Unfortunately there is not equivalent to ref_ac_columns_search=true in Catalog Item/Portal. A workaround could be for users to employ * search. It is not ideal, but it does enable searching all columns, not just the 1st one.
-O-
And you're welcome, of course šŸ™‚
