Knowledge Base Articles for Events and Alerts
Henrik Jutterst
Just out of curiosity, what is the best way to handle generic Events and to display a specific KB-article for that Alert
Example:
An event of low disk space on a host that creates an alert. And on that alert we get the Related Search Result, that display KB Articles.
We have 30 applications that use this baseline monitoring, but we have 25 different KB articles for this type of event/alert.
What is the best way to get the relevant KB article to show up on the alert record for a generic monitoring rule? I want the relevance to be as high as possible for the correct KB-article of a generic alert.
  • Add meta tags for the application service or host?
  • KB Structure?
  • Other?
Ahmed Drar
The best way to go about that is to make your relevant articles easy to find in terms of search, so the keywords for relevant articles should be found across different areas of knowledge article(Short Description, Description, and Meta)
Here is an example :
1 - Keywords found in Short Description, Description, and Meta -> this article always shows up first
2- Keywords found in Short Description and Description
3 - Keywords found in Meta
4- Keywords found in Short Description
 5- Keywords found in Description
Ahmed
Please mark my answer as ✅ Correct / Helpful based on the Impact
Barry_W
Mega Guru
As others have said, use the short description and meta fields to include terms specific to each alert, which if done correctly, should produce search results based on the short description of the case/alert.
You may find the below article helpful, which explains exactly how search results are calculated. Note the section on 'weighting' attributed to each field within the article, in particular, short description and meta. Test some different combinations of terms in a non-production environment and note the relevance scores. You can use these to fine tune the terms you include in each article.
https://docs.servicenow.com/bundle/sandiego-platform-administration/page/administer/search-administr...
Thanks for the link Barry. That made it a bit clearer!
