Knowledge Homepage UI Actions for example Create an article, import articles
ochiengboniface
Giga Contributor
Hallo community,
Is it possible to hide/disable the UI buttons?
Any help/idea will be greatly apppreciated. Thanks
ochiengboniface
Giga Contributor
Just to update the question. We asked servicenow and this is the answer i got
>> Is there a way we can either disable it or make it apply the template the way the create new module does? <<
The requested option of either disabling the button or change the form to use the template is not applicable as this is using angular JS and not allowed to change it. This is how it is designed in the out of the box and unfortunately no option to change it. "
9 REPLIES 9
From your original request, this is how you would restrict the button completely.
Go to UI Actions, Choose Create Article and remove the check box. find_real_file.png
Hallo Blaze,
i have disabled the Create Article UI Action but the 'Create An Article ' button on the Knowledge homepage is still there( see Attachments ).
Best Regards,
Boniface
ochiengboniface
Giga Contributor
Blaze2
Glad you were able to get this resolved. Hopefully it is a change that they can implement at a later update
reza
It might be late and no longer relevant,   but there are some properties you can use like:
glide.knowman.import.hide_import_functionality.
Im not sure about the others though
/ARS
