making CHECKBOX variables READONLY and MANDATORY NOT working
10-19-2020 01:27 PM
HI,
I hvae a onchange normal clientscript code which runs on sc_task when state changes. from the display BR i am taking the checkbox variables from the RITM and based on that i need to make the other set of checkboxes READONLY and MANDATORY. All the variables after submitting the request goes READONLY.
MY code goes as below:
var st=g_form.getValue('state');
if(st=='3'||st=='4'||st=='7'){ // when state is complete/incomplete/skipped
if(g_scratchpad.computer=="true"){
g_form.setMandatory('variables.received1',true);
g_form.setReadOnly('variables.received1',false);
if(g_scratchpad.headset=="true"){
g_form.setReadOnly('variables.received2',false);
g_form.setMandatory('variables.received2',true);
if(g_scratchpad.keyboard=="true"){
g_form.setReadOnly('variables.received3',false);
g_form.setMandatory('variables.received3',true);
This code is working fine, but when i test this, i observe that sc_task form gets saved if atleast one checkbox is true.
It is not maknig all the checkboxes mandatory, If one of the checkboxes is true form gets submitted.
Please assist me with this.
Service Catalog
Service Portal
10-19-2020 01:36 PM
Correct the sequence and try
10-19-2020 01:38 PM
You can also create a UI policy for this in the Catalog Item itself which is easier and Run it only on Requested Item and Task and uncheck the 'Applies on a Catalog Item view' checkbox.
10-19-2020 01:40 PM
i cannot get the state field from sc_task from catalog UI policy
10-19-2020 01:42 PM
checkbox variables are getting editable and mandatory as i needed, but when i make one of these checkboxes true leaving the rest unchecked, form gets submitted where it should not since they all are mandatory checkboxes
10-19-2020 01:49 PM
Did you try this? Does it make the variables mandatory?
