Multiple approvals reset in Flow Designer
geeerard
I took my first shot at creating a Flow for a new Service Catalog item. The flow works correctly for the most part, however, we have 3 levels of approvals which need to be met in order to generate the final catalog task.
The first approval to the manager is met correctly, however, the two additional approvals below that, reset any prior approvals.
The second approval step, will update the prior manager approval back to "Requested" when it was already approved. (work notes on the manager approval log the 3 state/field changes: requested, approved, then back to requested)
The third approval step will reset the prior two approvals, as well as send email notifications to the prior requestors. (who had already approved) We do not see this behavior with the older "workflows" we have for other catalog items. Has anyone else experienced this? I've included a few screenshots of the flow, I can expand any step if needed. Thank you in advance!
In case anyone else is looking at this, it is a bug. Here is the problem record on HI PRB1372267
9 REPLIES 9
Did the 15 second timer work for you? In my case all the approvals get marked back to "Requested".
Vlad
Brent Falkenste
I recently ran into this exact same issue with approvals in flow designer and after a deeper investigation I discovered that Approval Engines were still enabled on the Requested Item table which was causing the conflict between approvals generated in a flow versus older approval engines.
When I selected "Turn Engines Off" the issue was resolved and approval engines were no longer able to be set on the table.
Asad Ali
I ran in the similar kind of issue and  Brent Falkenste's  solution worked for me as well.
Just turn off the approval engine for requested item table.
No_name
4 years pass and bug still remain...
Jesse_H
I found that setting the Approval Field on my Ask for Approval actions to 'approval set' instead of 'approval' for all Ask for Approval actions running on the same RITM fixed the retriggering of my first approval to the manager.
