Problem process flow formatter missing
Cory Miller
Giga Expert
The process flow formatter is missing from our Problem Management Problem form
In the SN Docs on Problem Management > Assess a Problem it shows a Process Formatter at the top:
https://docs.servicenow.com/bundle/newyork-it-service-management/page/product/problem-management/tas...
I have looked at the list of UI Formatters under System UI and found a bunch for everything except Problem.
Under Configure Form there is no option to add a Process Flow formatter...
What am I missing?  How do I fix this?
Thank you in advance for any help.
Cory Miller
Giga Expert
I opened a HI ticket with ServiceNow and they said it is an issue for anyone skipping over Madrid.
Apparently I would have had to activate a plug-in in Madrid.
But, because we skipped over Madrid and went from London to New York, the Madrid plug-in for Problem is not available because it would cause data corruption.
I accepted the solution provided by ServiceNow, which is a migration tool so there will be no data loss.
The tool is supposed to be available in May of this year (2020).
9 REPLIES 9
Ankur Bawiskar
If you don't have it in the UI Formatters for that table then it won't show on the form
Yes, I understand.
My question is why don't I have that?
It seems I should have it, it appears to be an out of the box feature...
How do I correct this?
I would think I could export the UI formatter from the developers instance, which I may have to try.
But why? This is of concern to me why I would be missing this.
Incidentally, We recently upgraded from London to New York.
Hi @Ankur Bawiskar ,
I have the process flow formatters as follows,
But they are not visible on the form,
If you can help?
Vaishnavi
Prateek kumar
Two things to check here:
1. The table has the state flow created.
https://community.servicenow.com/community?id=community_article&sys_id=032de6e5dbd0dbc01dcaf3231f961...
2. It is included in the form layout of the form?
Please mark my response as correct and helpful if it helped solved your question.
-Thanks
