Problem with client script and script include comparing dates
patricklatella
Hi Community!
I've got a date field in an order guide that I want to add a field message to if the value of this field is less than 7 business days in the future.   I've got a catalog client script and a script include for this.   Problem is that (seemingly) random dates in the future that are more than 7 business days are triggering the field message.
Notice in my screen shots that the message is showing for a date way out in May, but only on that day, and not the date 1 day before or after.   Odd??   Anyone see a problem in my scripts below, or have a better way to achieve my goal?   Is there an OOTB GlideDateTime API method that I could use instead?   thanks!
Here's my client script:
g_form.hideFieldMsg('needed_by_date');
/************* This Checks whether the selected date is within 7 business days ahead**********/
  var ga = new GlideAjax('ClientDateTimeUtils');
  ga.addParam ('sysparm_name','withinBusinessHours');
  ga.addParam ('sysparm_hours','54');
  ga.addParam ('sysparm_requestedDate',newValue);
  ga.getXML(CheckScheduleAgainstDatesParse);
  function CheckScheduleAgainstDatesParse (response) {
  if(answer == 'False'){
                      g_form.showFieldMsg('needed_by_date','You are requesting a new user setup too close to their scheduled start date.   Please be advised that IT equipment cannot be guaranteed on their first day.','error');
and here's my script include "withinBusinessHours" function:
withinBusinessHours: function() {
var retVal; // Return value
var pn     = this.getParameter('sysparm_hours');
var requestedDate= this.getParameter('sysparm_requestedDate');
var reqDateTime = new GlideDateTime(requestedDate);
gs.log(reqDateTime);
if(pn > 0){
    //Get a schedule by sys_id to calculate duration
var schedule = new GlideSchedule();
schedule.load('090eecae0a0a0b260077e1dfa71da828');
    //Get the current date/time in correct format for duration calculation
    var actualDateTime = new GlideDateTime();
    actualDateTime.setDisplayValue(gs.nowDateTime());
//Create variable to capture the date we want to compare against
//requestedDate = new GlideDateTime("2017-06-16 00:00:00");
//Date difference calculated based on specified schedule
var difDay = schedule.duration(actualDateTime,reqDateTime).getDayPart()*24;
var difHour = schedule.duration(actualDateTime,reqDateTime).getDurationValue().split(':')[0].substr(-2);
var dif = difDay + parseInt(difHour.replace(/^[0]+/g,""));
if(dif >= pn){
retVal = "True";
retVal = "False";
gs.log(retVal);
return retVal;
No. It was parseInt. Use the code I just posted. It should be fine now.
var pn     = Number(this.getParameter('sysparm_hours'));
if(pn > 0){
gs.log('+++++++++++++actualDateTime+++++++++++'+actualDateTime );
gs.log('+++++++++++++reqDateTime+++++++++++'+reqDateTime );
gs.log('+++++++++++++difDay +++++++++++'+difDay );
gs.log('+++++++++++++difHour+++++++++++'+difHour);
var dif = Number(difDay + Number(difHour));
gs.log('++++++++++++++++++Total Hours ++++++++++'+ dif);
gs.log('++++++++++++++++++hours to compare   ++++++++++'+ pn);
if(dif >= pn){
retVal = "True";
retVal = "False";
gs.log(retVal);
return retVal;
32 REPLIES 32
Yes. Lets keep it simple. Also try the scenario which was failing. And multiplying by days with 8 instead of 24.
if(pn > 0){
var difDay = schedule.duration(actualDateTime,reqDateTime).getDayPart()*8;
var dif = difDay + difHour;
gs.log('++++++++++++++++++Total Hours ++++++++++'+ diff);
if(dif >= pn){
retVal = "True";
retVal = "False";
gs.log(retVal);
return retVal;
patricklatella
OK I punched that in, but also saw an error in the 6th gs.log, "diff" needed to be "dif".   got this from the log.   I'm going to try that last one again
So looks like it is fine now. Try for all you scenarios. I just reverted 8 to 24 again because 24 was correct.
So the final one below should work fine for you.
if(pn > 0){
if(dif >= pn){
retVal = "True";
retVal = "False";
gs.log(retVal);
return retVal;
patricklatella
ok, appear to be close...but it's throwing the error all the way out to Feb. 1.   Going to try multiplying days with 24.
patricklatella
so I put the 24 back in...but with
it's throwing a "False" for dates in February...which is incorrect.   But if I do January 24-31, 2018, it returns true (2nd screen shot).   So again, it appear somewhat random.   It's working for 5.2.18, but not for 4.3.18.   I'm going to try var dif = difDay + parseInt(difHour.replace(/^[0]+/g,"")); again
