Problem with client script and script include comparing dates
patricklatella
Hi Community!
I've got a date field in an order guide that I want to add a field message to if the value of this field is less than 7 business days in the future.   I've got a catalog client script and a script include for this.   Problem is that (seemingly) random dates in the future that are more than 7 business days are triggering the field message.
Notice in my screen shots that the message is showing for a date way out in May, but only on that day, and not the date 1 day before or after.   Odd??   Anyone see a problem in my scripts below, or have a better way to achieve my goal?   Is there an OOTB GlideDateTime API method that I could use instead?   thanks!
Here's my client script:
g_form.hideFieldMsg('needed_by_date');
/************* This Checks whether the selected date is within 7 business days ahead**********/
  var ga = new GlideAjax('ClientDateTimeUtils');
  ga.addParam ('sysparm_name','withinBusinessHours');
  ga.addParam ('sysparm_hours','54');
  ga.addParam ('sysparm_requestedDate',newValue);
  ga.getXML(CheckScheduleAgainstDatesParse);
  function CheckScheduleAgainstDatesParse (response) {
  if(answer == 'False'){
                      g_form.showFieldMsg('needed_by_date','You are requesting a new user setup too close to their scheduled start date.   Please be advised that IT equipment cannot be guaranteed on their first day.','error');
and here's my script include "withinBusinessHours" function:
withinBusinessHours: function() {
var retVal; // Return value
var pn     = this.getParameter('sysparm_hours');
var requestedDate= this.getParameter('sysparm_requestedDate');
var reqDateTime = new GlideDateTime(requestedDate);
gs.log(reqDateTime);
if(pn > 0){
    //Get a schedule by sys_id to calculate duration
var schedule = new GlideSchedule();
schedule.load('090eecae0a0a0b260077e1dfa71da828');
    //Get the current date/time in correct format for duration calculation
    var actualDateTime = new GlideDateTime();
    actualDateTime.setDisplayValue(gs.nowDateTime());
//Create variable to capture the date we want to compare against
//requestedDate = new GlideDateTime("2017-06-16 00:00:00");
//Date difference calculated based on specified schedule
var difDay = schedule.duration(actualDateTime,reqDateTime).getDayPart()*24;
var difHour = schedule.duration(actualDateTime,reqDateTime).getDurationValue().split(':')[0].substr(-2);
var dif = difDay + parseInt(difHour.replace(/^[0]+/g,""));
if(dif >= pn){
retVal = "True";
retVal = "False";
gs.log(retVal);
return retVal;
No. It was parseInt. Use the code I just posted. It should be fine now.
var pn     = Number(this.getParameter('sysparm_hours'));
if(pn > 0){
gs.log('+++++++++++++actualDateTime+++++++++++'+actualDateTime );
gs.log('+++++++++++++reqDateTime+++++++++++'+reqDateTime );
gs.log('+++++++++++++difDay +++++++++++'+difDay );
gs.log('+++++++++++++difHour+++++++++++'+difHour);
var dif = Number(difDay + Number(difHour));
gs.log('++++++++++++++++++Total Hours ++++++++++'+ dif);
gs.log('++++++++++++++++++hours to compare   ++++++++++'+ pn);
if(dif >= pn){
retVal = "True";
retVal = "False";
gs.log(retVal);
return retVal;
32 REPLIES 32
patricklatella
I think that's working!   testing thoroughly now.   the Number() function was the key?
Yeah...that was the key. parseInt was not working
Thanks Sanjiv. Its very painful working with schedule. but your post resolved my headache.
Atul Kumar
