Reference qualifier not working for location field
Jake Adams
I have a custom choice field 'Type' in the cmn_location table with choices as A, B, C and D. In the CMDB table I am using a reference field 'Location' which refers to cmn_location.
I have applied a simple reference qualifier as below:
Type is A or Type is C
But while click the magnifying glass in the 'Location' field it is only showing Type A records and not Type C. Am I missing something here?
Should work fine
but try this as well -> are you sure the choice values are correct and those are not Choice labels.
javascript:'u_type=Data^ORu_type=Data Center';
regards
Should work fine
regards
I used this advanced qualifier javascript:'u_type=Data^ORu_type=Data Center';
and then in the attributes I removed the tree_picker=true and it's working now, Is that a cause?
tree_picker might be an issue.
If you remove tree_picker and use this then it should still work fine
javascript:'u_typeINData,Data Center';
