RITM showing State as Work in Progress greyed out
Winnie P
Hello there. We have a few RITMs, Stage = Completed & State = Work in Progress.  All Tasks are Closed Completed.  How can you change the State = Completed if the option is greyed out please? Thank you.
Winnie P
Quick solution, from Support HI
Log in as admin > Access the Requested Items list > Click on cog wheel to Customised list columns > add State field to list > change State from WIP to Closed Completed
14 REPLIES 14
Hi
To correct data in Production, for records, that have to be "corrected against" normal behavior, you best write a script in any sub prod instance and test it good, to be sure that it will do what you expect.
Then copy the script (even via clipboard) and execute it on Prod.
You can navigate to "Fix scripts" which are intended for exactly cases. They also log that they ran, and when. Even, that you do not execute them twice, which is often critical.
Have a brief look ar the ServiceNow docs online, to read about Fix Scripts.
Let me know if that answers your question and mark my answer as correct and helpful.
BR
Dirk
Hi
Please write a business rule on sc_task table on before insert update
and in filter condition select state is close complete. I also attached screenshot of my code into attachment
Now in advance section
var flag = true;
var gr = new GlideRecord("sc_task");
gr.addQuery("request_item",current.request_item);
while(gr.next())
if(gr.state!=3)
flag = false;
if(flag){
var gr = new GlideRecord("sc_req_item")
gr.addQuery("number",current.request_item)
if(gr.next())
gr.setValue("state","3");
gr.update();
please mark my answer as correct and helpful
Virendra Mali
Thank you Vendra. I am getting the script error when trying your business rule, sorry I don't have any scripting experience:
I managed to remove the javascript parse error. However, can you please advise what your business rule does?  Will it allow me to change the few RITMs where State is Work in Progress to Completed? Thank you.
Please add one more } after line 25.
Saji
